02-21-2008 09:42 PM
02-21-2008 10:15 PM
02-22-2008 08:55 AM
02-22-2008 09:21 AM
02-22-2008 10:02 AM
02-22-2008 01:36 PM
When you say it reads nothing, I think you mean you read zero, right? It sound that you basically want to trigger (send the 100ms 5 Voltspulse) to the camera when the “break screen” is open and it can’t carry the voltage. What is the voltage you read when the screen breaks? Can you post some picture of how the signal looks before and after the screen breaks?
I think you might be able to check for voltages levels and generate a pulse when your signal drops to zero or to whatever voltage it is dropping.
Waiting for your reply
02-22-2008 02:14 PM
02-22-2008 02:14 PM
02-25-2008 12:21 PM
From your previous code “waveform graph 3” is not going anywhere so I guess you have updated your code. Causes of NI-DAQmx Error 50103 "The Specified Resource is reserved, this is a very good article that shows the possible reasons for this error. In your case I think is case 1.
I hope it helps
