I use this VI and have no problem independently opening and closing the relays. Check that the Close Exclusive input is set to "Normal". Also, are you sure that the Channel List input only has a single entry? Using your example, the first time you run it, the channel list should be 102,103 with Open/Close set to close. The second time, the channel list should be 103 and Open/Close set to open.
