How can I measure phase difference between two pulse trains using two counters on multifunction DAQ
Highlighted
Is it possible to use two counters in a DAQ to measure phase difference between two pulse trains? If possible, Which DAQ should I use? Thanks
(1,451 Views)
Highlighted
If you take a look at the NI Examples there is one named
Counter - Read Pulse Width and Frequency (Continuous).vi
Browse according to Directery Structure and look at
DAQmx>>>Counter Input>>>Counter - Read Pulse Width and Frequency (Continuous).vi
In that VI, there is a tab for 2 Edge Separation measurement. If you run the VI with this tab selected it will give you the time between edges of the two waveforms.  You wil lthen have to convert the time to a phase (based on the frequency of the two waveforms).  I ran it with ctr0 selected and first and second inputs were PFI8 and PFI9.
Randall Pursley
(1,426 Views)
Highlighted
Thanks for your reply. Would this vi work with any DAQ w counter? I heard this type of measurement only works with a DAQ counter w/quadrature encoder function. What is the DAQ model# that you are using?
(1,408 Views)
Highlighted
Hey mchips,
If you open up this example from NI Example Finder, you'll see a section called "Requirements" in the bottom right corner of the window.  This lists the DAQ hardware compatible with the highlighted example.
Myriam
Applications Engineer
(1,377 Views)
