How can I make this VI save every 5th image?
This Vi allows me to control the number of images I save, but I want to ALSO save every 5th image because the grab is too quick. I want some time between each save. Any ideas on how I can do this without removing things from this VI.
(3,009 Views)
Your specifications are not clear to me.
  • Do you want to save every 5th image unconditionally?
  • Do you want to save every 5th image when the button is pressed until you have the desired number of images?
(3,003 Views)
every fifth image when the button is pressed until the desired number of images.
(3,000 Views)
Can anyone give me some insight on this?
(2,963 Views)
Use this code, but:
  1. Multiply the value from "# of images" by five.
  2. Inside the case, divide the shift register value by 5 using quotient&remainder.
  3. Place the "save" code inside another, even smaller case structure.
  4. Wire the remainder from (2) to the case selector. Save only if the remainder is zero and execute a blank case otherwise.
  5. tweak for details. 😉
See how far you get. 🙂
(2,959 Views)
