12-05-2010 05:02 PM
Please help me , I have to make a vi that counts letters from a text that I give him in a string. I have to tell him what letter to count from the text . I am using labview 6
Solved! Go to Solution.
12-05-2010 05:46 PM
What else do you need than the String Length function?
12-05-2010 09:53 PM
Since LV6 is presumably missing the nifty Search and Replace String function you can always do this:
12-05-2010 10:20 PM
Ah, count a specific letter as opposed to all letters.
12-06-2010 04:03 PM - edited 12-06-2010 04:04 PM
Thank you very much for the vi. It was extremely helpful . I am starting to learn labview. I want to make another project to use in my home. I want to control with labview some different type of utilities. For start I want to make a vi that acts as a time relay.
I want to select De type of relay :
I want to make him with 3 options:
-to start after a preseted time
-to stop after a preseted time
-to wait for a preseted time, start, run for a preseted time, and then stop
I want to see it running with a Boolean led, after that I will want to figure it out alone how to connect it from the computer to the utilities.
I am using labview 6.
12-06-2010 04:10 PM
If your original problem was solved you should mark the thread as SOLVED and Kudos to the person that solved it for you.
You should then start aNEW topic for your NEW problem, as the subject no longer reflects the question.
Alan
12-06-2010 05:12 PM
SOLVED
12-28-2010 03:32 AM - edited 12-28-2010 03:33 AM
hy. i'm from Romania,so forgive me for my english.
I need urgent this program for a school homework.I posted the program here but I do not go, please help me, tell me where I'm wrong.LV 8.5
12-28-2010 04:51 AM
Right click on the constant U8, go to representation, and select U8
Prashant
12-28-2010 04:59 AM
thank you very much,
PCSNF
I wish you a happy new year!!!
