How can I lock a tab control untill fuction within tab is complete?
Hi
I am a little stumpt.  What I would like to do is to lock a Tab control until the fuction within the tab is complete (and have a dialogue box saying something like "fuction 1 must stop before you can run function 2").
I realise some event based programming would have been best but I wonder if there is a quicker fix as the code I produced is quite complex now.
I attach an example (tab control and two case stuctures) to clarify what I need to do.
I know there is probably a really simple answer so sorry to be so dim.
Many thanks
Ash
(3,796 Views)
Hi Ashley
Just use the "Disabled"-property of the tab control. Set it to either 1 or 2 (disabled or disabled & gray) before your activity starts and set it to 0 (enabled) after the activity finished.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,790 Views)
Hi Thomas
Presumably this is done programmatically using the property node.
However I  can't find the trick to control each tab seperately.
(3,786 Views)
Hi Ashley,
Take a look at the enclosed example.
The property "Pages" give you an array of refernces to the separate pages of the tab control.
andre.buurman@carya
André (CLA, CLED)
(3,782 Views)
Why do you want to disable the tabs separately?
Using LV8.0
(3,775 Views)
Hi again Thomas
I think I probably haven't explained what I am trying to do very well.
Basically the tab control gives access to two separate block diagrams inside a case structure.  I attach an amended example to explain better.
I can see I don't need a disable function as clearly, niether case will run until the other has stopped.  All I need I suppose is a dialogue box pop up saying "case 1 must be stopped before case 2 can be run and vice versa" or for case 2 to be greyed out whilst case 1 is running and vice versa.  I am sure I am making this more difficult than it really is.
I will fix it in the end.
Many thanks
Ash
(3,758 Views)
I'm still of the opinion that you need to disable the tab control. It's quite hard to give advice without knowing the background. Ok, I know what you want to accomplish, but I don't know how it fits in the rest of your app.
Ha look at the "wizard" template which could be another solution for you.
Using LV8.0
(3,753 Views)
