How can I interface HC-SR04 ultrasonic sensor with freeduino board in labview
I have an HC-SR04 ultrasonic sensor. I have already integrated it with an arduino board v1.1.
I have a DAQ module (NI USB - 6009) with me. Will I be able to display distance measurement with labview using the above module?
Awaiting a good response.
(3,872 Views)
I don't quite understand. You have an existing sensor connected to an arduino and now you want to connect it to the 6009?
(3,853 Views)
I have already connected with arduino and displayed distance output in lcd 2 x 16 display.
Now, I would like to show the same using labview. i am having Ni 6009 module with me currently. I want to know whether this is enough for me to integrate with labview.  I need the steps to connect since i am mechanical and i dont know anything about electronics.
(3,829 Views)
There is a tool called LIFA that interfaces between 'duino's and LabVIEW. Note that it does not program the 'duino but rather it gets and sets information between them. See LIFA. There is a specific discussion concerning using your sensor with the 'duino here. I'm not sure how much LIFA supports the freeduino.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,818 Views)
ill try that. thank you.
(3,801 Views)
