How can I have each pass through a for loop communicate with a new indicator?
I am using 16 color boxes to indicate how 16 channels are behaving.  If a color box is blue, its respective channel is running correctly, red means it has failed etc.  I am continuously checking each channel using a loop, and I wanted to update the channel colors every loop.  I have made an array of 16 numbers corresponding to the color I wish to have (which are blue = running, red = failed, green = completed, black = not in use).  However, I cannot find a way to pull these 16 numbers out of the array and to the color boxes short of 16 index arrays connected to the color boxes.
I understand how to convert each individual number to a color, I just don't know how to use a 16 times for loop to communicate with a different color box each pass through.  Is there any way to do this or should I just go for brute force?
Thank you.
(2,400 Views)
Put the 16 color boxes in an array and index them into the loop
Message Edited by elset191 on 07-06-2009 02:00 PM
Tim Elsey
Certified LabVIEW Architect
(2,398 Views)
Accepted by topic author M. Bobby
I just realized the color boxes are indicators probably.  In this case you can put references to the color boxes in an array and wire the reference to a property node and change the color that way.
Tim Elsey
(2,387 Views)
Sorry I keep making new posts.  Attached is an example i wrote up.  There are three cases in the disabled structure, each has a different implementation of what i belive your specs are.
Tim Elsey
(2,364 Views)
The reference/ property node combination is working very well!  Thank you very much.
(2,355 Views)
