How can I get the Lable value of Recessed Menu Ring Ctrl?
There are two characters in the control setting of "Recessed Menu Ring" Ctrl which are "Lable" and "Vaule"(Lable/Vaule Pairs). Use "GetCtrlAttribute" function can only get the value of "Value". But I want to get the vaule of "Lable". I find nothing relation to "Lable" after I search all the control attribute in the "GetCtrlAttribute" function. How should I do?
(2,745 Views)
I am not aware of a "Recessed Menu Ring" in LabVIEW. Are you sure you're in the right forum? Could it be you're using LabWindows?
Anyway, in LabVIEW you would get the "String and Values[]" property of a ring control. (The label property refers to the label of the menu ring and not to one of the ring choices.)
Message Edited by altenbach on 07-19-2005 11:31 PM
(2,741 Views)
I'm so sorry for the wrong forum
(2,730 Views)
