How can I get the LabView talk to my DAQ bord?
I'm a first time user. I can write to Digital port with my MAE but when I run LabView example I see nothing on output.
(2,556 Views)
First I assume that MAE is MAX (Measurement and Automation Explorer). If you can use your digital port with MAX your card and driver is correct.
Check the settings in MAX for your card. Under devices the device number must meet the number in the examples. All examples will use device 1 as default.
If this does not help tell us which board you have, how it is configured in MAX and which LV Version and example you use and what error occurs in the error handler.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,556 Views)
