How can I get more detail information about ActiveX controls?
I would like to know more about the available properties, methods and events of an ActiveX control, instead of just a list of them. How and where can I get them?
(2,709 Views)
Most ActiveX controls come with a help file that you can access. I would check for something like this first. Is there any control in particular which you are researching? Let us know and I can look for something for you.
J.R. Allen
(2,709 Views)
Many (not all) of the available properties have their own help.
First select a property of interest, THEN right click. You MAY then see a new selection that says "Hlep on XXXX".
I have not quite figured out when and where these "other" helps are coming from (yet).
For MS stuff, make sure you install help for VBA.
Ben
(2,709 Views)
