How can I get XY graph look like that picture
Hi GerdW
     I  can not understand your .
The XY Gragh can not draw the very same look of those plots ?
 "using a picture indicator and to draw your plots on your own" How can i do it?
Message 11 of 21
(1,169 Views)
Can the toolkit DIAdem do it?
Message 12 of 21
(1,166 Views)
Hi liang,
"The XY Gragh can not draw the very same look of those plots ?"
This says: using a XY graph you will not get exactly the same look as your reference picture.
""using a picture indicator and to draw your plots on your own" How can i do it?"
Well, you can draw in a picture indicator. There is a whole palette with drawing functions. Use them to draw something like your reference picture! You will see there's a lot of work along that road...
About DIADEM:
- That's not a toolkit, it's a full-blown software on its own...
- You may ask in the DIADEM forum - or you download the trial version and test for yourself...
Message 13 of 21
(1,163 Views)
Hi GerdW
You mean that I can use" Plot XY.vi ","Plot multi.Xy.vi "  "Calc.scal.specs.vi"   ......
But I am a beginner ,and the examples in VI are the suite for my picture.
Can your give me some examples about it?
Are there other methods draw my picture(like call matlabe)?
Message 14 of 21
(1,139 Views)
A. Use 2 graphs, then you can have "half" scales.
B. Don't use the grid.  Make the graph background transparent.  Put your own grid behind the graph.
George Zou
Message 15 of 21
(1,124 Views)
HI Zou
  I am a beginer. I can not understand you.
 Can you give me some example ?
Thank you !!
Message 16 of 21
(1,119 Views)
SOmebody can help me ?
Thanks !!
liang
Message 17 of 21
(1,103 Views)
Hi liang,
did you try any of the offered solutions given in this thread and in your other thread regarding the same topic?
Did you go through any of the LabVIEW basics courses on NI website?
You already got all the help you asked for...
Message 18 of 21
(1,097 Views)
Hi GerdW
   Firstly , Thank you for you help!
   I have tried solutions given in this thread ,but i cannot solved this problem!
   I have refer to many example In Vi , and can not find the solution for my problem?
liang
Message 19 of 21
(1,089 Views)
Hi zou :
     YOu mean that I need to creat 2 graghs and merge them.
    Can you tell me how can i get grid with dot line.
liang
Message 20 of 21
(1,060 Views)
