How can I create a pulse train with varying pulse widths?
I'm trying to create a finite pulse train that varies its duty cycle. I was hoping there was a clever way to do this neatly. I've attached a very rough picture of the train I'm hoping to make, with the pulse widths defined with t, the delay between pulses d, and a total of N+1 pulses. Thanks!
Edit: My current method is to use the pulse train function, and actually create 2N+1 pulses, stacking the "double length" pulses.
(3,222 Views)
This pseudo code should do the trick.
pulse train (time,t,d)
    cycle=floor(time/d)
    timeintocycle=time-cycle*d
    if timeintocycle<=(cycle+1)*t return high else return low
end function
(3,187 Views)
I wound up just building the first short pulse, and then the train of longer pulses, and sticking them together. I attached a screenshot of the code I went with.
(3,166 Views)
Hey don't go overboard with the gratitude.
(3,153 Views)
Like going overboard with the local variables. None of those are necessary.
(3,149 Views)
