How can I create a exe file with a tab control on it that work´s ?
I have a VI with many controls and indicators,these are spread on a tab control.This tab control works with out any problems but if i create a exe file then the tab control is fixed. How can I create a exe file so that the tab control on it work´s ?
(2,761 Views)
Hi, i don't think that problem is with tab control.
We must see your vi or screenshot of you VI.
Please, attach them here.
(2,761 Views)
I have made a new Posting with the same question but this time I added a screenshot of the VI.
(2,761 Views)
I am not sure what exactly you are seeing as incorrect behavior. Are things not dissapearing when you change tabs? Are the controls on the tab moving? Do you have an activex control on your tab? Any specific information you can provide would be helpful.
Jeremy
(2,761 Views)
Well When I make a exe file of my VI the tab control on it was fixed on one position, if I test it as a normal VI then I did not have this Problem. What I did was I made the tab control a control and not an indicator, then I made a new exe file and it worked perfect. Thank´s on all those who help me solved this problem.
ps Special thank´s on Adam Russell.
(2,761 Views)
