How can I create a GIF file ?
Does anybody know, how can I create a Gif file with LV.
I had used the print option (Print to HTML file) from LV but I can't use it
when I
create an application with appbuilder.
Does anybody know another way to carry it out?
Thanks in advance
(3,439 Views)
It works with a LabVIEW 6 built app of mine. What kind of error do you get when you try it? Attaching the VI would also help.
(3,439 Views)
Hi Dennis,
I also have LV 6 and get no errors.
Printing the frontpannel directly on the printer works fine.
Do you know a posibility to redirect the printer output to a Gif -file?
"Dennis Knutson" schrieb im Newsbeitrag
news:5065000000050000006C4C0000-1004225886000@exchange.ni.com...
(3,439 Views)
I was talking about the properties of the documentation tool which creates an html file and allows for the selection of GIF as an image format. The GIF files are the front panel, diagram, and icon. You didn't specify what you are trying to print but if you need something else, let us know.
(3,439 Views)
You understood me correctly but the properties of the documentation tool
doesnt exist
after building the application (Runtime Version). Only the Menu "File /
Print Window" option is present. Therefor I looked for another way to do it.
news:506500000005000000A24C0000-1004225886000@exchange.ni.com...
> else, let us know.
(3,439 Views)
I mistakenly thought that my built app was working correctly but I looked again and it generates an error. It may be because the property expects to find a diagram and there is no diagram with a built VI. If you want to try printing a subVI, what might work then is if your top level VI called a subVI that was in a normal .llb.
(3,439 Views)
