How can I control or send data to a Borland C++ application from a LabView program
I need to sent data to a borland c++ application from labview program. Is it possible. I mean I need to syncronize my C++ application from labview program.
Sincirely,
Umit
(2,925 Views)
You can try to use ActiveX or dll's!
BR, Christian
(2,910 Views)
If it is possible, a sample code will be great for me.
Best Regards,
(2,903 Views)
Hi umitc,
There are some very good examples on how to do this in the LabVIEW example finder.  My personal favorite would be Call DLL.vi.  Hope that helps.
Brian K.
(2,877 Views)
Thank you very much for your help.
I tried the example and I wrote such a dll but when I try to use the same dll in a VS C++ project and a labview project, te dll uses different memory location. When I sent a value to dll and when I try to see it in my vs C++ application, I could not see the values. How can I communicate with my VS C++ and labview project. The dll must use the same memory location for my aim.
Best ragards,
Umit
(2,860 Views)
Hi umit,
I am a little confused about what you are saying.
1)  Do you have exported functions that LabVIEW can call?
2)  Are you receiving an error?
3)  How does your DLL differ from the example?
Brian K.
(2,845 Views)
Best ragards,
Umit
As you have already seen, LabVIEW and VC++ running in their own process.   The memory space is not shared between process.
What you need is Inter-Process Communication.  Call Dll.vi alone is not going to slove your problem.
If you are a good C/C++ programmer, search MSDN site for Inter-Process Communication.  There are a few choices.
You have to impliment one of those method in a dll, so you can call the dll in LabVIEW.
George Zou
http://gtoolbox.yeah.net
George Zou
(2,835 Views)
