How can I connect to my PCI-6221?
Hello!
I have a PC with a PCI-6221 measurement card installed.
I'm new in NXG and I cannot find a possibility to do the same like I did with the DAQ-Assistant before.
David
(2,374 Views)
If you are using NXG 1.0 you can use DAQmx 17.0 and up. If you are using NXG 2.0 you can use DAQmx 17.5 and up.
http://www.ni.com/product-documentation/53853/en/
(2,352 Views)
Hello!
I tried to find the DAQmx in Labview NXG, but without result.
Do I have to install something? Driver e.g.?
David
(2,340 Views)
Yes you will need to install NI Device Drivers that came with your installation media. I'm not sure if device drivers support current gen and NXG, but if you don't have any device drivers you might try the Jan 2018 drivers and see what happens.
http://www.ni.com/download/ni-device-drivers-january-2018/7178/en/
(2,336 Views)
