I have a subVI that I call to scan incoming data. When I stop scanning, I want the window to close and return to the front panel of the calling VI. Can someone help me please? Thanks in advance! Dave
"Dave G" wrote: >>I have a subVI that I call to scan incoming data. When I stop scanning, >I want the window to close and return to the front panel of the calling >VI. Can someone help me please?>Thanks in advance!>Dave
Dave, If I get it correctly all you need to do is to follow steps below to get rid of VI front panel after execution. *-ON the Front Pannel go to VI Icon and right click. * Select VI Setup. * Select Execution Options * click on Show front pannel when called * click on close afterwards if originally closed. Make sure to save your vi with some other name and try on it.
Rgds,
Hasan
