How can I check to see that a spreadsheet (comma delimited) contains only numbers?
Checking for zeros is probably an order of magnitude faster than testing the strings. As crossrulz said, you need to be absolutely certain that zero is never a valid or possible value.
Lynn
Message 11 of 12
(804 Views)
The sensor is used as a controller for a biological system. The system dies if the sensor value is zero, so it should go into disaster mode if they're legitimate.
Message 12 of 12
(790 Views)
