07-01-2009 02:04 PM
I have several large folders of images I pulled from a framegrabber. Each has between 300-500 .bmp images which are named 0, 1, 2, 3, ... , 365. The problem is that when I use Vision Assistant to open the images it opens them out of order. Ex: 1, 10, 100, 101, 102, ..., 11, 110, 111, ..., 12, 120, 121, ...
What is even more frustrating is that there doesn't seem to be a way to reorder the pictures, nor do I think I want to spend the time to do this for the 16 folders of images I am working with.
Thoughts... Ideas?
07-02-2009 12:06 AM
would request to repost on Machine Vision Forums for effective Results.
http://forums.ni.com/ni/board?board.id=200
Sundar.
07-06-2009 11:04 AM
07-06-2009 02:51 PM
07-07-2009 10:08 AM
Hi WuTang4eva,
The duplicate post link was added to direct users to the accepted solution.
