> How can I change the defaultcolor of the plots in a xy-graph, when
> there is a large series of plots in that graph
> In LabVIEW 6 the defaultcolor of a plot in an xy graph is different
> for every plot. I use large series of plots to draw errorbars on my
> datapoints. It In LabVIEW 5 the default color was white, which was
> fine. Now my graph is excessive colorfull.
> Changing in a loop the color of every plot is far too slow. I need to
> change the default color.
It isn't currently possible to affect the default colors. To speed up
the loop setting colors, you can either make the plots on the graph be
empty or better and easier, set the panel property to Defer Panel
Updates to True, set the colors, then set to False.
Greg McKaskle
