Every time I setup a UI in Labview (6.1, 7.0, or 7.1), I find myself setting an attribute, the same attribute, for multiple identical front panel objects to the same setting. Usually, I try to mitigate this by setting the attributes before I make copies of the original object; however, I am often changing things as I program which leads to my problem. So is there a way to select several identical/similar objects and set the same attribute on all of them to the same setting all at once (instead of 20 times/attribute)?
Thanks.
