Hello, I believe the VI that you are looking for is the System Exec.VI. The VI is located on the communications palette. This VI will allow you to execute a system command such as notepad.exe or some other executable file. Heath
> I want to call an EXE file from LabVIEW "directly" without any DLL > wrapper. How do I do it? >
The node is called System Exec and it is in the Application Control palette I think -- with the VI Server Functions. You basically give a command line and some options for synchronization, etc.
