How can I boot my PXI controller into real-time without a floppy disk?
Highlighted
My PXI controller is in a lab which has intense magnetic fields that could corrupt the floppy disk used to boot the PXI controller into the LabVIEW Real-Time (RT) Operating System. How can I boot the PXI controller into real-time directly from the hard drive?
(1,580 Views)
If you are using LabVIEW 5.1.2 Real-Time (RT), launch Remote System Explorer and select Disks >> Create Format Hard Drive Disk. If you have LabVIEW 6 RT, launch the Measurement and Automation Explorer (MAX) and select Tools >> RT PXI Disk Utilities >> Create Format Hard Drive Disk (LabVIEW RT 6 has not be released yet). Once you have created the disk, boot the PXI controller with the Format Hard Drive Disk, and this will format the PXI's hard drive and install the real-time OS boot loader. Now you can reboot the PXI without a floppy disk and configure the PXI using Remote System Explorer or MAX. Be aware that this will remove all information from the hard drive, including other operating systems.
(1,580 Views)
