I have three "while loops" that are executed in parallel, two generate values and the third while loop write the values in a spreadsheet.
The run time of each while loop is different, to synchronize the three while loops I use a "Wait Until Next ms Multiple", but sometimes the same value is kept twice.
I think that a solution would be to add a "Write To Spreadsheet File" in the blocks that generate values, adding a new value in the wished column in each cycle, but I do not know like doing this.
I could keep the values in two arrays and add them in a same spreadsheet in different rows or columns, but I need save values in spreadsheet in each loop and not all values at the end of cycle.
Thanks.
German Garrigos.
