10-15-2020 11:20 AM
I have tried "Amplitude And Level Measurements" but it just spits out complete nonsense. Is there another vi that does this?
10-15-2020 12:00 PM
Hi crash,
It really would help to attach an example VI with your example data to confirm this "complete nonsense".
All those functions provided from NI usually do what is explained in their LabVIEW help entry…
When you attach your VI with your example data you should also provide the expected result!
10-15-2020 12:25 PM
On the "Amplitude And Level Measurements" VI did you modify the "state settings" input to use the "Peak" option instead of the default "histogram" option?
Failing that, you can always use the "Get waveform components" node to separate out the array of floating point numbers inside the waveform, and run that through the "Array Max & Min" node to get the highest and lowest values.
10-16-2020 12:15 PM
I do not see state settings anywhere. I will try the latter option.
