How can I access PCIe FlexRIO with Integrated IO RTSI port?
Hello, I was using PCIe 57xx with PCIe 1477, both are PCIe FPGA devices.
I have managed to connect these devices together with RTSI Cable, but when I make a pair of simple FPGA code to read/write RTSI port, nothing seems to happen?
I don't know it is because I have failed writing or failed reading? Or is the problem come from PCIe 1477 or PCIe 5763? Anyone can give me some advice?
I really appreciate any help you can provide.
(926 Views)
You have definitely forgotten to attach your VI to your post!
Rolf Kalbermatter
My Blog
(902 Views)
The RTSI reading/writing code is actually simple, I only put these IOs in SCTL and make R/W operation there.
I also had a photo of how these two cards connected, the connection seems right to me.
(885 Views)
Well, a photo is not a VI!!!!
I'm sorry but my eyesight isn't quite that of an eagle and my screen isn't 50" across and your camera angle is pretty bad too.
Rolf Kalbermatter
My Blog
(874 Views)
Never mind, I already know what's going on there, FPGA code alone is not enough to access RTSI port, I also need to access FlexRIO API v1 to routing source to RTSI in host VI.
(864 Views)
