08-10-2007 07:06 AM
08-10-2007 07:15 AM
I've not had to do this myself but I suspect what you are looking for is in the Windows Registry. Just be carefull not to nuke something you really need!
Look in HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\PCI\ or \ISA
08-10-2007 07:28 AM
08-10-2007 08:03 AM
08-10-2007 10:45 AM
Earlier I said that if an 8-port card is installed that COM25 through 32 would be used. I intended to say that it's unknown what will happen. In this case, I just installed an 8-port card and it was assigned COM7 through 14. Please see the attached screen shot.
Apparently it starts at COM7 because earlier I had a 4-port card where it used COM3 through 6.
However, COM11 is associated with ASRL15. Why is COM11 not associated with ASRL11? This causes problems in the LabVIEW application. How can I fix this?
An earlier reply mentions the Windows registry. I'll look into this but I don't think I can tolerate having end-users modify the registry.
I've poked and proded around in MAX, NI-VISA and NI-SERIAL and cannot find the function similar to "remove unassigned ports." This is an intriqueing function. Please refind it when you get a chance.
How can I get the LabVIEW application to programatically determine the ASRL numbers?
08-10-2007 11:19 AM
08-10-2007 12:33 PM
08-11-2007 06:43 AM
08-11-2007 10:28 AM
I posted a similar question a while ago & got the following response from NI, "that is not a supported feature of NI-Serial".
Here's the post:
http://forums.ni.com/ni/board/message?board.id=140&message.id=22835#M22835
-Jerry
08-13-2007 04:18 AM
I'm working on a procedure to use the Recover unused COM Numbers function and I'm still working things out. In the mean time I have a question.
What is the purpose of the C:\VXIPNP\WinNT\NIvisa\visaconf.ini file? It seems that changes I make to this file does not make any difference in the operation of the serial ports. Is this file used? If it is used, how is it used? What application creates the file and/or uses it?
Dave
