03-23-2016 01:03 PM
I need to have 42 high speed digital pins to test a MRAM. I have 2 PXIe 6556 cards but don't know how tight/accurate the syncronization of the two boards is.
I didn't see any specs that talk about using multiple cards. Anyone know what I can expect to achieve?
Joer1
03-24-2016 11:35 AM - last edited on 01-10-2024 02:11 PM by migration-bot
Hi Joe,
It looks like William may have answered your question in your service request. However, I will reiterate the information again here:
When synchronizing two cards in one PXIe chassis, the most effective method is to use TClk. This will have both devices PLL to the 10 MHz reference clock, and share their start trigger. This would let you synchronize the devices to within 500 ps, which should work for your 35 ns read access time. Here is a resource on what NI-TClk is and how to use it: https://www.ni.com/en/shop/pxi/national-instruments-ni-tclk-technology-for-timing-and-synchroni.html
There is also a shipping example, Multi-Device Dynamic Generation (TCLK), under Hardware Input and Output>Modular Instruments>NI-HDSIO>Synchronization that might help get you started.
Hope that helps! 🙂
03-24-2016 03:10 PM
Yes, William did a great job tracking it down for me.
Thanks All!
Joe Riordan
