11-01-2011 01:20 PM
The killer is, you are not adding value through this whole process. You end up spending a lot of time and ending up with basically what you had before. Only on a newer version of LabVIEW. End users have a hard time understanding this. At our plant, we are starting to skip versions of LabVIEW just because of this. We are updating every 2 years now, and probably every three years in the future. The added features are not worth the pain and lost productivity the yearly updates were causing us. It was a serious problem for us. We keep versions available for support purposes on other PC's if we need them. If you go up a couple of versions, a lot of little things end up changing and cause the program not to work properly. And worst of all, you may need to shut production down to fix these problems.
11-02-2011 07:13 AM
I can agree to what. If you compare Labview 8.6 with Labview 2011. You will find find no major differences. I do not say it is no differences. But the big lines are still the same. The thing that we get a "new" Labview version every year is more a marketing strategy, in order to sell more. But it is also important to plan for life length. I think you will find out that it is shocking many Labview 5 and 6I applications still running out there, with NI hardware from the same period. The day such an system give up it can create serious problem. You will not be able to replace anything. And the person who made the system is long gone, and the same may be true for the source code.
07-24-2017 01:37 PM
Hi Matthew, I am sorry that if I have brought back the topic again after few years later.
Do you have any step by step instruction on how to install multiple versions of RTE into PC?
I have newer versions (2017) installed previously. I tried to install older version (2013) but the installation summary always tell me that "cannot install NI LabView Run-Time Engine 2013 because higher version already installed".
07-24-2017 01:51 PM
Could it be that 2013 is already installed, but in a slightly newer patch level? What happens if you try to tun the 2013 executable? From where did you download the 2013 run time engine?
07-24-2017 02:06 PM
I just get my new PC from company.
So, I installed directly to latest version (2017).
I got RTE image disk in my old PC which is in 2013 and I try to install over here.
Is it not a proper way on doing this?
07-24-2017 02:38 PM
You installed LabVIEW 2017 or the 2017 RTE? If you installed LabVIEW, it is very likely that there was a toolkit or driver etc that uses the LabVIEW 2013 RTE and therefore you have it installed. If you look in MAX, you can get a list of the installed NI software, including the Run Time Engines.
07-24-2017 07:40 PM
I didn't know that the MAX able to view the software that I've installed.
I installed everything. It is long list, I am just capturing part of it. [see attached]
I have all the runtime installed in my PC.
Then, how can I create executable for previous version?
The message it popped out after I try the executable on old version of RTE:
"Unable to locate the LabView Run-Time Engine.
Application.exe requires a version 2017 (or compatible) LabVIEW Run-Time Engine."
07-24-2017 08:45 PM
Telasdist wrote:Then, how can I create executable for previous version?
Only with a previous version of LabVIEW.
07-26-2017 12:20 PM
Luckily, I managed to find the old installer for LabVIEW 2013. I am now able to create the executable for older version. Thanks for the help.
