How I can see cluster updates of a VI in the main?
Hello!
I'd like to ask a question;
I have a VI that are doing some calculations, depending on the results, the data are updated in a cluster, the user is seeing updates cluster on the front panel. The cluster is an output of VI.
When I use the VI in the main, I can’t see the updates of the cluster, I only can see the final value.
I've also tried to use global variable, but I can not display them on the main VI.
Thank you very much!
Message 1 of 22
(3,930 Views)
What do you mean by updates here?. How you are updating the cluster?
Message 2 of 22
(3,923 Views)
Attached the files. I need run the main and see the changes in the cluster in the same window. Depending on the values of the cluster, I'll do something different in the main.
I hope to explain well.
Thanks.
Message 3 of 22
(3,918 Views)
If I am correct you want to display all the values updating in the cluster from subvi to the main vi.... If this is the thing, try using the reference of the cluster in the main vi and pass it to the subvi.
Rajashekar
Message 4 of 22
(3,912 Views)
yeah, that's what I need 🙂
Do you mean to pass the reference to use as input of VI? or how i can do it?
Message 5 of 22
(3,906 Views)
Yes, pass the reference of the cluster (present in the main vi) as the input to subvi (vi called inside main vi).
Rajashekar
Message 6 of 22
(3,901 Views)
it doesn't work. Any other help, please?
Message 7 of 22
(3,877 Views)
Can u convert the vis into Labview 7.0 and post it so that i can check it.
Rajashekar
Message 8 of 22
(3,874 Views)
Sorry, only let me to convert into Labview 8.0 😞
Message 9 of 22
(3,868 Views)
K....what is the problem u r facing.....
Message 10 of 22
(3,866 Views)
