06-04-2018 08:23 AM
I have two while loops, one for motor run and stop by arduino uno ,second for navigation between pages.
the problem is when i use only first program to run and stop motor it works but if i put another while loop of navigation the first while loop of motor didnot work.
how i can solve this problem?
Solved! Go to Solution.
06-04-2018 08:34 AM
You probably shouldn't have so many sequence structures, they're usually not necessary and are actually a hindrance. Can you post actual code (VIs) instead of screenshots?
06-04-2018 08:44 AM - edited 06-04-2018 08:44 AM
@arteitle ha escrito:
As arteitle said raplace the sequence structures with a State Machine Architecture.
06-04-2018 08:57 AM
How to run two parallell loops? Place to independant Whiles.
