Problem: I have developed an application with the LabVIEW DSC module and I created and used an NI Security Domain. Now I want to move this application to another network or PC. How can I keep the Domain settings for the new PC/network?
Solution: You should copy the directory located at
Program Files\National Instruments\Shared\Domain
to the same location on the destination PC. To apply the changes you should restart your computer.
You can also completely remove the NI Security Domain (if you forget your password, etc.) by deleting all the files from this
Domain
folder.
