How I can get my waveform chart to reset every time the user pushes a button?
My program takes in a DAQ input and displays this signal in a waveform chart continuously. I would like the previous values to be removed from the waveform chart display every time the user presses a button (a boolean toggle). Any ideas on how I can do this? I am relatively new to Labview and do not know where to begin in solving this problem.
(25,749 Views)
Have a look at this page.
CLA
(25,746 Views)
Accepted by topic author Laura121
There's a property node for that.  Put something like this in your UI loop, if you have one.
Jim
(25,720 Views)
You can use History property node and wire an empty array to clear the data of chart.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(25,719 Views)
That worked, thanks, right click on block diagram icon of the chart, create/property node/ (bottom of drop down is the history data).
(20,945 Views)
