How Does Serial Port Works
Just posting when you asked for that Smiley Very Happy
Mensaje editado por Juanjo Vega
Message 11 of 15
(1,115 Views)
Although, I think this aspect in the serial port is not all the well documented it should.
Hope other's could avoid that kind of problems thanks to these post.
Remember: Right-click over the serial port read and/or write block to avoid problems. Smiley TongueSmiley Very Happy
See you!!
Message 12 of 15
(1,097 Views)
Hi Juanjo Vega,
I'm also currently working with a scorbot system, the Performer M2K that uses the Controller-B. I'm trying to get my hands on the ATS 2.0 software for the Controller-B specifically.
I have version 1.9 that is for the Controller-A. So I'm not sure of the differences between these two versions but I'm wondering if you have access to ATS 2.0 for the Controller-B?
I'm hoping the ATS 1.9 I have will work the same, but I'm still troubleshooting and thought the software version might also be adding to the RS232 comunication problem.
Gerry O'Brien
robotics@digital-circuitry DOT com
Message 13 of 15
(852 Views)
hi,
I want to control scorbot er-ix through visual c++. I have ATS and Scorbase. Regarding the code required to control scorbot, cn u tell me hw did u get to knw the signals to be sent thru the serial port to perform the desired task. And is it possible to control the robot solely thru hyperterminal. Are the commands for hyperterminal and ATS the same.
Message 14 of 15
(643 Views)
I am exactly working on the same issue, but for SCORBOT ER V. I have only the SCORBOT ER V, the CONTROLLER A and ACL software active on my PC. It would be of great help if you can tell me how to send commands to the CONTROLLER A throught LabVIEW or MATLAB through the RS 232 interface. Its my thesis.
Amar Makana.
Message 15 of 15
(538 Views)
