There is the "Gaussian White Noise Waveform" vi or the "Gaussian White Noise" vi. Try typing "Gaussian White Noise" into LabVIEW help. As to the filtering, there are numerous filter VIs available, check out the examples. Help->Find Examples->Analyzing and Processing Signals
Actually in the moment you specify a sample rate for your Gaussian white noise data you apply a filter equal to F_sample/2. But anyway If you want to have 10 seconds with white noise sampled with Y Hz in sample frequency. Then you create an white noise array, with 10xY samples or elements. Then you apply your filter
Besideswhich, myopinionisthatExpressVIsCarthagemustbedestroyeddeleted (Sorry no Labview "brag list" so far)
