Hi all
How Can I make this Work! Look at my VI example.
The VI runs, and the I start to switch the Integrating slide to true. and the random data can be seen in the Peak And Volume indicators.
Then if I swith the Flow/Temp slide to True (Temp) and the Integrating slide is true, I want the it (The integrating slide) to auto switch to false.
Now If i switch the The integrating slide to true it must remain true!,
So If I then swith the Flow/Temp Slide back to false( Flow), Nothing happens with the Integrating slide.
If I then switch the Flow/Temp Slide to true( Temp), The integrating slide must reset to off again. and so on...
Sorry for the long explaination.
In my Attached Vi, I got it work autoswitching to false, but when The F/T slide is set to Temp, the Integrating slide will not switch to true!!
Can any body see the problem!
rgards
ZAMZAM
HFZ
