09-25-2021 07:50 AM - edited 09-25-2021 07:52 AM
Hi everyone,
I need help from experienced friends.
I can successfully get tokens with Postman application. But I also want to do this using labview.
Attached is the information I sent with the Postman application. I want to send this information with labview as well. Help please..
09-25-2021 01:48 PM - edited 09-25-2021 01:52 PM
Hello again,
Finally I managed to get Tokens.
But when I tried to access some information with "Get" I was not successful. How can I write data from "raw json" like in Postman? 1
04-01-2022 05:01 AM
You said that you manage haow to get the access token on labview.
Can you share me the code you did?
