Horizontal scrollbar of waveform chart in tab page resets to end when tab page switched
Hi X
Could you attach a simplified version of the code with which we could reproduce the issue in our side? I used the Vi of this thread and I could not reproduce the issue.
Regards
Esteban R.
Message 11 of 16
(1,695 Views)
Message 12 of 16
(1,684 Views)
Hi X
I downloaded the VI but I have not been able to reproduce the issue, I have Windows 7 64 bits and  LabVIEW 2013 32bits.
Could you send me a screenshot of the error?
Have you seen the error video that is in this tread? Does it have the same behavior in your computer?
Regards
Esteban R.
Message 13 of 16
(1,667 Views)
I am using the latest patched SP1 LV 2013 version on Windows XP 32 bit.
I can't watch that video.
Here is what happens:
Step 1: Run
Step 2: Move the scrollbar mid range
Step 3: Tab to Page 2
Step 4: Tab back to Page 1
Observe how the scrollbar (and graph) has snapped back to the end of the range.
This is a bug by any other name and that is a VERY ANNOYING one when you design an interface.
Message 14 of 16
(1,664 Views)
Hello X.,
Thanks for posting your issue. Looking at it closer, I found that it actually does not have to do with the scroll bar and probably more with the default X Scale.Range:Maximum and X Scale.Range:Minimum being used to redraw the chart.
I have made some slight modifications to the program you sent in which should show how dynamically set the minimum and maximum of the chart so we can keep its position when flipping through tabs.
JY
Application Engineer, RF and Communications
Message 15 of 16
(1,569 Views)
I have missed this late answer.
This indeed the workaround I have been using for a while (years) now, but this needs to be:
- filed a CAR for (please post the CAR number back in the thread for future reference)
- fixed
Message 16 of 16
(1,519 Views)
