01-09-2007 06:46 AM
01-09-2007 10:09 AM - edited 01-09-2007 10:09 AM
As far as
my German goes, I think you're asking for a way to programmatically change the
settings of the "Create Histogram" ExpressVI. What you have to do is
right-click on the ExpressVI icon and select the German equivalent to
"Open Front Panel" - it's probably called "Frontpanel
öffnen". That will change the ExpressVI to a regular SubVI and you can
then edit its input and output terminals. Here's the Create Histogram after I
converted it to a subVI and added the three additional inputs:
I hope that it answers your question.
Message Edited by Philip Courtois on 01-09-2007 05:10 PM
01-10-2007 04:55 AM
Thanks a lot, now I have the next Problem, after changing the ExpressVI to a regular SubVI the Minimum and Maximum value is always 8 when I open the VI.
What can I do, if I don`t want to edit these values every time I open the VI. I want to define standard values for the Maximum, the Minimum value and the number of Bins. I only want to give the possibility to edit the number of bins on the frontpanel.
Thanks a lot for answering.
01-10-2007 10:21 AM
01-10-2007 11:17 AM
01-10-2007 12:36 PM
01-11-2007 07:27 AM
As you can see in the attached screenshot I can not set the current values as default values.
01-11-2007 09:56 AM
