03-21-2019 02:26 PM
Looking to see if anyone has already written a VI for the Highland Technologies T560 delay generator. I am particularly interested in a VI using the ethernet interface. I have search the VI libraries but didn't find one.
03-22-2019 07:57 AM
I see that this device has both Ethernet and RS-232 capabilities, which suggests that it may use a simple command protocol, possibly over a VISA interface (which can travel over Ethernet). I could not find a manual on-line to confirm this, but you presumably have one.
What I would suggest is to study the manual and see how it says to communicate with the device. If my guess is correct that you can use VISA over TCP/IP, then I'd recommend you start as follows:
03-25-2019 10:33 AM
Bob,
Thanks for the reply. I am further along now than when I posted. I am successfully sending commands and reading responses over ethernet simply using TCPIP open, write, read, and close VI's. So I have the basic communication already working. I am working on my own group of VI's.
I tried the MAX program but could not get that to work. The button for "add new deice" does not show up. Someone here with more Labview experience than me thought I didn't need MAX and that turned out to be true. Still it bothers me that MAX does not seem to work the way the manual says it should.
My original post was to see if anyone else had already written a comprehensive VI for the T560 so I could leverage someone else's work.
The manual for the unit is linked from their website, in case you are interested.
https://www.highlandtechnology.com/dyn/files/doc/T560MANK5.pdf
