High speed data aquisition using C9215
Hi
         I used the attached code for acquiring high speed data using C9215 I/O module. But i feel some distortion in the aquired signal. Can anyone review my code and give me the solution .
Thanks in advance,
Sooraj
Design Engineer NeST
(2,752 Views)
Hi Sooraj,
Can you be a bit more specific?  When you say you "feel" there is some distortion in your signal, what does this mean (quantitatively, or even qualitatively looking at a graph of the data).
Also, can you narrow down the issue to specific VIs (i.e. which Real-Time VI with which FPGA VI is causing the issue)?
This, and any more information you can offer would help us to support you and get you going in the right direction towards a solution!
Message Edited by Brian_A on 07-07-2008 10:07 PM
Brian A.
(2,686 Views)
