04-04-2022 10:06 AM
@JÞB wrote:
See msg3 no Rube-Goldburg required. Pretty simple: if you want to output a constant value, output the value of a constant.
Well IMHO this was either a poorly written question... Or a real dick move.
As there is a a valid application of trying to keep an output within a certain range given varying inputs.
Trying to trick the students with a BS question like that takes a real piece of work of an instructor.
04-04-2022 10:32 AM
The quality of the answer can typically not exceed the quality of the question (but of course we try very hard!!!).
Here, the question was so ambiguous that all hope for a solution is lost in the swamp
For example 0.47xx could be read as 0.47x^2 and 0.47xxxx as 0.47x^4
04-04-2022 10:40 AM
"42" has an above average change though!
04-04-2022 12:44 PM
But No-one remembers the question after 5.5Gyears
04-04-2022 12:58 PM
The instructor is tricking students.
He said initially x = 0.095 and the final result should 0.4715......
04-04-2022 01:10 PM
@GRCK5000 wrote:He said initially x = 0.095 and the final result should 0.4715......
So what is he saying now??? And what do the "......" stand for? What should the result be for other typical x values?
04-04-2022 01:13 PM
So he is saying xxxxx can be any number. As long as The first three digit is 0.47, I should be good. smh
04-04-2022 01:20 PM
Ok, so the result does not depend on the control x at all? Why is it there?
04-04-2022 05:53 PM
I have a suggestion:
Works great on the front panel, just don't put it in your loop controller ; )
04-05-2022 03:02 AM
How did you manage to get a typo into the 1 thing you typed???
(I would have used copy paste 😁)
Otherwise, it's funny.
