01-26-2012 03:28 PM
i want to design a program for air flow detector ..can anyone help..or has anyone got a program that i can use?
01-26-2012 03:31 PM
Let's keep this all in one place.
01-26-2012 03:55 PM
Well at least there is a better question than the last time here.
For one we are not a code writing group. You need to try things and come back for HELP. Asking for someone to do this for you is a little over the top. Do some research and figure out what it would take start some code by exploring the great examples that come with LabVIEW and then come back and ask specific questions.
Hey will you buy me a car? It is really the same thing. For what some of the guys charge per hour when not volenteering here, it might be cheaper.
01-26-2012 04:08 PM
guys
no need for harsh replies..am only asking for help
01-26-2012 04:13 PM
Air flow detector. Does MSc = Mundane Science?
Of course if you use the detector to measure the speed of a DeLorean....
01-26-2012 04:15 PM - edited 01-26-2012 04:18 PM
@yasmin wrote:
guys
Yeah but we already know this is school work so asking for a "program you can use" is not going to get you very far around here. Sorry.
EDIT: BTW, welcome to LabVIEW and the forums! Don't get scared away, this a a great resource. We just like clear and specific questions. It makes it easier to help (which is why we're here).
01-26-2012 06:04 PM
You need a hot-wire anemometer. You can get one from http://www.omega.com. You will also need some kind of hardware that can read the signal it puts out. First you need to decide on the anemometer that fits your needs then find out what kind of hardware you can use to read the signal from it. If you are feeling adventurous you can try to figure out how to use one from a car. The mass airflow sensor is a hot wire anemometer.
01-27-2012 03:23 AM
It is very simple but moreever It depends on the hardware which you want to use...
Simply you need to make acquisition software compatible with your hardware platform.
Hope it helps...
With Regards,
Devang
+91-8884938693.
