04-19-2021 02:38 AM
I'm using keithley 2450, and I want to get my data as a text form or excel..
but I don't know how,,
and I think there's a power limit because when I put values over 1V, the program says "exceed Power limit"
anyone who might help me?:(
Solved! Go to Solution.
04-19-2021 03:03 AM
Hi dfw,
So you "don't know" how to get your "data as text"?
You already get the "data as text" from your device! Use File functions to save that text into a file…
I guess the real problem is your lack of knowledge about LabVIEW, so I recommend those "Training resources" offered in the header of the LabVIEW board…
I guess you should read the manual of your K2450 device to learn about all its options/specifications. This should give you the answer about the power limits and how to set/change them…
(In your VI there is only one control labelled "limit". As it is connected to a "Configure Output" function it may help to read the help for that specific function, too.)
