matic motor and the other to a mutshibishi motor, I already have the code for the gammatic motor, I need an other one for the mutshibishi one....guys, I come from a production management engineering backgound and I sack in programming, would anyone help methe idea behind is to see an accuracy between the data entered in term of positon, speed motion of the 2 axis of the scara robot and the data received
matic motor and the other to a mutshibishi motor, I already have the code for the gammatic motor, I need an other one for the mutshibishi one....guys, I come from a production management engineering backgound and I sack in programming, would anyone help meNagui,
Unfortunatley I cannot help you devlop all of your code. Are there any perticular areas that you are having problems with at the moment that I could help you with??
What do you mean by integrated trajectory planning functions? Could you give an example of what you would use these functions for? Our SoftMotion toolkit can do path planning and trajectory generation, is that what you are talking about?
