Hex concatenating...
Thank you! I was completely lost in all this byte/hex talk and was just trying to piece together what seemed like the obvious solution and what I found in other forum posts. This is simple, easy to follow and most importantly IT WORKS!!!
Message 11 of 19
(333 Views)
Message 12 of 19
(314 Views)
@RavensFan wrote:
Simpler
This is the way I usually end up doing it, but I always make sure the output is correct, mostly because I'm paranoid that I will eventually find a case where it doesn't work.
Bill
CLD
(Mid-Level minion.)
Message 13 of 19
(297 Views)
Accepted by plasmageek
I typically slightly complicate it by using a well named typedef (not shown) cluster and "bundle by name".
Advantage:
  1. Self-documenting
  2. You'll get coercion dots if you wire a constant with the wrong representation
  3. Defaults value can be set in the cluster, no need to wire them as constants.
  4. etc.
A typedef cluster also makes it easy to go the other way:
(NOT SHOWN: Of course you might want to do some validation, e.g. check the string length, etc. Note that "unflatten from string" would have "error" and "remaining string" outputs and is a little bit safer. Similarly, use "flatten to string". You can even set the byte order.)
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 14 of 19
(293 Views)
Advantage:
  1. Self-documenting
  4. etc.
Well, yes.  That's really the way I do it, but the general idea was what I was in agreement with.  🙂
Bill
CLD
(Mid-Level minion.)
Message 15 of 19
(289 Views)
Advantage:
  1. Self-documenting
  4. etc.
I like to arrange my clusters like this:c.png.
To do that automatically, place the attached file in C:\ ... \LabVIEW ????\Project\.  After that, you'll be able to select the cluster and chose "Arrange Cluster Constant Nicely" from the tools menu.
Message 16 of 19
(265 Views)
@paul_cardinale wrote:
Advantage:
  1. Self-documenting
  4. etc.
I just skip all that and use the icon.  At that point, I'm more interested in what it is than what's inside it...
Bill
CLD
(Mid-Level minion.)
Message 17 of 19
(252 Views)
Hi Paul,
Thanks for this VI.
Small bug report: It mostly works, but has problems to align array constants inside the cluster:
using LV2020 on Win8.1+cRIO
Message 18 of 19
(222 Views)
I love this solution with the added constant to document everything.
Thanks for all the great solutions!
Message 19 of 19
(197 Views)
