Hex command for serial communication
Highlighted
Dear Community,
please have a look at the attached code.
For the specified inputs n1=20 and n2=21 I need the string output indicator to be:
020D140D150D (hex display)
instead i get
020D31340D31350D.
How can I achieve that?
Thanks in advance
(772 Views)
Highlighted
Accepted by labviewette
Don't convert the numbers to a string. Just create the byte array and then use "byte array to string"
Certified LabVIEW Architect
(758 Views)
Personally, I like to use Replace Array Subset to build up these types of commands.
GCentral
(753 Views)
Highlighted
Everyone has their favorite methods -- I prefer Format into String (right-click and look at Edit Format String and "adjust as needed").
Brief explanation:  \\ means a single backslash (backslash has a special meaning, so \n is NewLine), %x means "number as hex", and ordinary characters mean themselves.
I have to say I don't understand why the original formulation didn't work (it wasn't something you did, as it didn't work for me, either ...).
(739 Views)
Highlighted
That code does not produce the desired outcome. He wants the byte data, not the ASCII string.
I don't understand. Of course it doesn't work. The number is converted to a string. Maybe you didn't notice his output string indicator is set to hex display.
(726 Views)
Highlighted
Right -- I missed that detail ...
BS
(719 Views)
Highlighted
yep, that's right what I need.
Thanks.
(716 Views)
