06-26-2013 03:43 PM
Hi there.
I am trying to write voltage data from a keithley 24xx to an excel spreadsheet with very high resolution(.0001 volts/amps). I have my instrument driver setup and i can input the values i want into the instrument and can see them on the display but when i go to the excel spreadsheet, any value under a miliamp is written as zero.
I have tried to change the rounding on the actual spreadsheet, using "to extended precision float" as well as other conversions but the program still writes the voltage/amperage values as an array of zero's.
Has anyone ever encountered this problem before? It seems like there would be a simple solution out there but it hasn't hit me yet.
Any suggestions would be greatly appreciated.
06-26-2013 03:48 PM
Hi proph,
maybe you should attach your VI or just show an picture of the block diagram?
- HOW do you write the data to a spreadsheet?
- Do you use RGT to write "real" Excel files or just WriteToSpreadsheetFile creating simple CSV files?
- When using WriteToSpreadsheetFile: did you set an appropriate format string? Default is "%.3f" which rounds to "milliamps". Try "%.6g" instead (or read the help for format strings)!
06-26-2013 04:15 PM - edited 06-26-2013 04:17 PM
If you are using the "Write to Spreadsheet" or "Array to Spreadsheet string" vi then use %S as the format string.
%S formats to your number to a string exactly as the number, no rounding or truncating will occur.
06-26-2013 04:44 PM
So My VI is bigger than just 1 page but here are 2 screenshotsof the writing process:
Im using write to spreadsheet file.The default value was indeed %.3f so I'm going to try to change the format and see if it works =D
06-26-2013 04:53 PM
Thanks guys! both solutions resolved my problem =D
