Help with connection for NI USB 6211 pls!
Hi, I was wondering if an LCD can be connected to the 6211, which has only 4 digital data output pins. It works fine on NI-DAQ6008 with 8 data pins. Is there any way I can connect it to 6211? As seen below I need P0.0 to P0.7 and P1.0 to P1.2, but there's only P0.0 to P0.3 and P1.0 to P1.2 on the 6211.
Here's how I connected it to the 6008. Attached is the LCD screen datasheet. Thanks.
Pin on 6008            LCD pin
      P0.0                     7 (DB0)
      P0.1                     8 (DB1)
      P0.2                     9 (DB2)
      P0.3                    10 (DB3)
      P0.4                    11 (DB4)
      P0.5                    12 (DB5)
      P0.6                    13 (DB6)
      P0.7                    14 (DB7)
      P1.0                      4(RS:REGISTER SELECT)
      P1.1                      5(R/W:READ/WRITE)
      P1.2                      6(E:DATA ENABLE)
      +5V                      2(POSITIVE POWER SUPPLY)
      gnd                       1 (GROUND)
a resistor is connected across pins 1 and 3 of the LCD screen, which controls the contrast of the LCD screen.
(2,486 Views)
Why do you want to change? If can suggest something. If your PC have a parallel port i guess this can be used for controlling your LCD. If you have trouble this may be your ticket out from them.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,474 Views)
Its coz the 6008 belongs to my college and its kinda hard for me to get it at times whereas I have the 6211. Is there any way I can do it with the 6211? BTW there's no parallel port on my PC, sorry.
(2,460 Views)
I can see your problem. If that help. The only advice I can give is that do not let other (an older) students bully you. If you need time with the 6008 device talk to your teacher and say you can not solve your assignment unless you get some time with the 6008 device. Perhaps some other students can use your 6211 device meanwhile you are working with the 6008. Just do not tell them that it is your device. Let them think the 6211 college property 😉
(2,455 Views)
Hi Flibberty,
If you cannot common any channel (have the same logic), you really need to change back to 6008.
There's no choice.
Regards, Kate
(2,434 Views)
